13 years agoCyclone V: Communication with EPCQ Device in User Mode after Bootup
For my design, I'm using the Cyclone V (5CEFA7F23). I'm looking to boot the "factory image" from an EPCQ flash device using Active Serial x4, and then from the factory image (when in user mode), com...
11 years agoI'll also add that the ALTASMI_PARALLEL block is just far too complicated for may uses.
All you need is a simple block to allow an Avalon master to bit-bang the interface. The most would be something to allow 32bit and 8bit reads/writes to be done an a single Avalon cycle. Everything else can be done with a very simple software interface - not based on the HAL code for the old EPCS flash controller which is a lot of library code that doesn't expose the interfaces the code needs.
