Lecsano
7 years agoCyclone V: Can`t write data to MT25QL256 user space with ASMII II
Hi. I have custom board with Cyclon V and MT25QL256 . Refer to "ASMI Parallel II Intel® FPGA IP Core User Guide", I can read, erase memory via SystemConsole. But "write_memory" command don`t work. ...
YuanLi_S_Intel
7 years agoHi Alexandr,
This is weird. By right the IP will automatically select the right code depending on the configuration device that you use. Just would like to check, have you selected the correct configuration device during the generation of POF file?
YL
