10 years agoCyclone V and Security
Hi there, I have a question about the Cyclone V security feature. As far as I know the security feature of Altera's FPGA's is used to protect the design of the FPGA from being copied or reverse...
10 years agoNo not only other FPGAs, but also other authentication devices like Atmels ATSHA204A or similar devices. So if I understand you right, there is space to secure store only one key in the FPGA. But If I need two authentications with different keys, then I have to take either another FPGA (which would be a bit overkilled) or a separate external authentication device, right? But it should not be a problem to use this key for generating a challenge & response authentication, is this correct?
