Mikexx
2 years agoCyclone V: A PLL with multiple clocks and independently adjusting phase of a clock
I have a PLL with 5 output clocks. 4 are at 56.25MHz and a fifth is at 225MHz that is used to sample the other outputs to confirm any phase shift in Signal Tap. The tick-box for "Enable access to ...
Mikexx
2 years agoSurely I can't be unique in being the only guy trying to shift the clock phases from a PLL.
Has anyone else successfully shifted the phases of multiple clock from a single PLL?
