12 years agoCyclone V - Megafunction "ALTIOBUF" Error
hello, i have some problems using QuartusII megafuction "ALTIOBUF". <I'm using Cyclone V(Cyclone V GX Starter Kit) and Quartus 13.1> I create a new megafunction(ALTIOBUF-select 'As an output ...
10 years agoI have same problems when using "Delay chain" of ALTIOBUF Ipcore with cyclone V.
When I create this ip core and install it as top-level entity, I can't complie it although I am success when using this ip core for stratix V. This is error code when i Ctrl+K: Error (129029): Input port DELAYCTRLIN[4:0] on atom "iobuf_ipcore:inst|iobuf_ipcore_iobuf_out_cg61:iobuf_ipcore_iobuf_out_cg61_component|sd1", which is a cyclonev_delay_chain primitive, is not connected to a valid source Info (129004): Input port DELAYCTRLIN[0] of the atom "iobuf_ipcore:inst|iobuf_ipcore_iobuf_out_cg61:iobuf_ipcore_iobuf_out_cg61_component|sd1" is driven by the output port OUTPUTREGDELAYSETTING of the atom "iobuf_ipcore:inst|iobuf_ipcore_iobuf_out_cg61:iobuf_ipcore_iobuf_out_cg61_component|ioconfiga_0", which is a cyclonev_io_config primitive Info (129004): Input port DELAYCTRLIN[1] of the atom "iobuf_ipcore:inst|iobuf_ipcore_iobuf_out_cg61:iobuf_ipcore_iobuf_out_cg61_component|sd1" is driven by the output port OUTPUTREGDELAYSETTING of the atom "iobuf_ipcore:inst|iobuf_ipcore_iobuf_out_cg61:iobuf_ipcore_iobuf_out_cg61_component|ioconfiga_0", which is a cyclonev_io_config primitive Info (129004): Input port DELAYCTRLIN[2] of the atom "iobuf_ipcore:inst|iobuf_ipcore_iobuf_out_cg61:iobuf_ipcore_iobuf_out_cg61_component|sd1" is driven by the output port OUTPUTREGDELAYSETTING of the atom "iobuf_ipcore:inst|iobuf_ipcore_iobuf_out_cg61:iobuf_ipcore_iobuf_out_cg61_component|ioconfiga_0", which is a cyclonev_io_config primitive Info (129004): Input port DELAYCTRLIN[3] of the atom "iobuf_ipcore:inst|iobuf_ipcore_iobuf_out_cg61:iobuf_ipcore_iobuf_out_cg61_component|sd1" is driven by the output port OUTPUTREGDELAYSETTING of the atom "iobuf_ipcore:inst|iobuf_ipcore_iobuf_out_cg61:iobuf_ipcore_iobuf_out_cg61_component|ioconfiga_0", which is a cyclonev_io_config primitive Info (129004): Input port DELAYCTRLIN[4] of the atom "iobuf_ipcore:inst|iobuf_ipcore_iobuf_out_cg61:iobuf_ipcore_iobuf_out_cg61_component|sd1" is driven by the output port OUTPUTREGDELAYSETTING of the atom "iobuf_ipcore:inst|iobuf_ipcore_iobuf_out_cg61:iobuf_ipcore_iobuf_out_cg61_component|ioconfiga_0", which is a cyclonev_io_config primitive Info (129030): Output port PADTOINPUTREGISTERDELAYSETTING of a cyclonev_io_config primitive is a valid source for input port DELAYCTRLIN[4:0] on atom "iobuf_ipcore:inst|iobuf_ipcore_iobuf_out_cg61:iobuf_ipcore_iobuf_out_cg61_component|sd1" Any one help me, plz!!!
