12 years agoCyclone V - Megafunction "ALTIOBUF" Error
hello, i have some problems using QuartusII megafuction "ALTIOBUF". <I'm using Cyclone V(Cyclone V GX Starter Kit) and Quartus 13.1> I create a new megafunction(ALTIOBUF-select 'As an output ...
12 years agoThanks for your reply.
i make the output buffer 'IOBUF_OUT.v' using MegaWizard Plug-in Manager. Top Level(TEST.v) code and IOBUF_OUT.v code are as follows : module TEST( out_datain, out_io_config_clk, out_io_config_clkena, out_io_config_datain, out_io_config_update, out_oe, out_dataout ); input out_datain; input out_io_config_clk; input out_io_config_clkena; input out_io_config_datain; input out_io_config_update; input out_oe; output out_dataout; IOBUF_OUT u2 ( .datain(out_datain), .io_config_clk(out_io_config_clk), .io_config_clkena(out_io_config_clkena), .io_config_datain(out_io_config_datain), .io_config_update(out_io_config_update), .oe(out_oe), .dataout(out_dataout)); endmodule //synthesis_resources = cyclonev_delay_chain 2 cyclonev_io_config 1 cyclonev_io_obuf 1 //synopsys translate_off `timescale 1 ps / 1 ps //synopsys translate_on module IOBUF_OUT_iobuf_out_ll61 ( datain, dataout, io_config_clk, io_config_clkena, io_config_datain, io_config_update, oe) ; input [0:0] datain; output [0:0] dataout; input io_config_clk; input [0:0] io_config_clkena; input io_config_datain; input io_config_update; input [0:0] oe; `ifndef ALTERA_RESERVED_QIS // synopsys translate_off `endif tri0 io_config_clk; tri0 [0:0] io_config_clkena; tri0 io_config_datain; tri0 io_config_update; tri1 [0:0] oe; `ifndef ALTERA_RESERVED_QIS // synopsys translate_on `endif wire wire_sd1_dataout; wire wire_sd2_dataout; wire [4:0] wire_ioconfiga_outputenabledelaysetting; wire [4:0] wire_ioconfiga_outputregdelaysetting; wire [0:0] wire_obufa_i; wire [0:0] wire_obufa_o; wire [0:0] wire_obufa_oe; wire [0:0] oe_w; cyclonev_delay_chain sd1 ( .datain(datain[0]), .dataout(wire_sd1_dataout), .delayctrlin({wire_ioconfiga_outputregdelaysetting[4:0]})); cyclonev_delay_chain sd2 ( .datain((~ oe_w[0])), .dataout(wire_sd2_dataout), .delayctrlin({wire_ioconfiga_outputenabledelaysetting[4:0]})); cyclonev_io_config ioconfiga_0 ( .clk(io_config_clk), .datain(io_config_datain), .dataout(), .dutycycledelaysettings(), .ena(io_config_clkena), .outputenabledelaysetting(wire_ioconfiga_outputenabledelaysetting[4:0]), .outputfinedelaysetting1(), .outputfinedelaysetting2(), .outputhalfratebypass(), .outputonlydelaysetting2(), .outputonlyfinedelaysetting2(), .outputregdelaysetting(wire_ioconfiga_outputregdelaysetting[4:0]), .padtoinputregisterdelaysetting(), .padtoinputregisterfinedelaysetting(), .readfifomode(), .readfiforeadclockselect(), .update(io_config_update) // synopsys translate_off // synopsys translate_on ); cyclonev_io_obuf obufa_0 ( .i(wire_obufa_i[0:0]), .o(wire_obufa_o[0:0]), .obar(), .oe(wire_obufa_oe[0:0]) `ifndef FORMAL_VERIFICATION // synopsys translate_off `endif , .dynamicterminationcontrol(1'b0), .parallelterminationcontrol({16{1'b0}}), .seriesterminationcontrol({16{1'b0}}) `ifndef FORMAL_VERIFICATION // synopsys translate_on `endif // synopsys translate_off , .devoe(1'b1) // synopsys translate_on ); defparam obufa_0.bus_hold = "false", obufa_0.open_drain_output = "false", obufa_0.lpm_type = "cyclonev_io_obuf"; assign wire_obufa_i = {wire_sd1_dataout}, wire_obufa_oe = {(~ wire_sd2_dataout)}; assign dataout = wire_obufa_o, oe_w = oe; endmodule //IOBUF_OUT_iobuf_out_ll61 //VALID FILE // synopsys translate_off `timescale 1 ps / 1 ps // synopsys translate_on module IOBUF_OUT ( datain, io_config_clk, io_config_clkena, io_config_datain, io_config_update, oe, dataout); input [0:0] datain; input io_config_clk; input [0:0] io_config_clkena; input io_config_datain; input io_config_update; input [0:0] oe; output [0:0] dataout; wire [0:0] sub_wire0; wire [0:0] dataout = sub_wire0[0:0]; IOBUF_OUT_iobuf_out_ll61 IOBUF_OUT_iobuf_out_ll61_component ( .io_config_clk (io_config_clk), .io_config_clkena (io_config_clkena), .oe (oe), .datain (datain), .io_config_datain (io_config_datain), .io_config_update (io_config_update), .dataout (sub_wire0)); endmodule
