Zak's avatar
Zak
6 years ago
Cyclone V - LVDS input on a bank with Vccpd=2.5V and Vccio=1.8V
I'd like to have a confirmation of what I found on the Cyclone V Device Handbook regarding mixed voltage standards on a single bank.
In my design I have multiple I/Os @ 1.8V and LVDS inputs on the same bank. Quartus doesn't issue any errors and the project compiles and fits successfully. I've done this because on the Handbook (Table 5-9: Cyclone V I/O Standards Voltage Levels) it's specified that LVDS inputs are only dependent to Vccpd, which is equal to 2.5V on my bank. There's also a note which says: "Input buffers for the SSTL, HSTL, Differential SSTL, Differential HSTL, LVDS, RSDS, Mini-LVDS, LVPECL, HSUL, and Differential HSUL are powered by VCCPD".
Can someone confirm that?
Thank you
  • Hi Zak,
    There is no issue to use mixed voltage standards on a single bank. As long as that particular I/O bank supported your I/O standard (Vccpd=2.5V and Vccio=1.8V)
    Matt
  • ShafiqY_Intel's avatar
    ShafiqY_Intel
    Hi Zak,
    Matt
    • Zak's avatar
      Zak
      Hi Matt,
      I know that there is no issue to use mixed voltage standards on a single bank. What I don't understand is if I can do it with LVDS inputs, since the Vccio requirements in Table 5-9 of the Device Handbook for LVDS inputs is not so clear.
      For LVDS outputs the requirements are Vccpd=2.5V and Vccio=2.5V.
      For LVDS inputs the requirements are Vccpd=2.5V and Vccio=? Is it not relevant since only Vccpd is used for input LVDS buffers?
      Thank you
        ShafiqY_Intel
        Hi Zak,
        For LVDS inputs the requirements is Vccio=Vccpd
        For LVDS outputs the requirements is Vccio=2.5V
        And for Cyclone V, the value for Vccpd is 2.5V
        Matt
