13 years agoCyclone IV IO bank power sequencing
I have a Cyclone IV device as a managment device for the balance of circuitry on a board. The FPGA comes up prior to much of the rest of the board being powered. The FPGA will be responsible for sequ...
13 years ago --- Quote Start --- I do like your suggestion of using some form of power switch for different portions of circuitry. The only hurdle here is the on resistance of such a switch. The one you've identified is not up to my requirements (possibly up to 1Amp). However, the principle is good. A P-channel FET with a low on resistance may suffice. It may also be possible to boost the 1.8V rail a little such that any voltage drop through the high side FET is negated and the other circuitry remains within spec (+/-5%). The Cyclone IV would be happy to operate at 1.8V+5%. --- Quote End --- Don't be afraid to use two regulators; the one for the FPGA could be a linear drawing a <100mA, whereas the 1A could use a switcher. Cheers, Dave
