10 years agoCyclone IV GX Transceiver Starter Board, Clocks & Ports issue with HDL Coder (MATLAB)
Hello, i'm new in this forum but i have a problem to configure the HDL Workflow Advisor from MATLAB with the information from my FPGA (EP4CGX15BF14). In the attachement you can see a pictu...
10 years agoYou can find pin information called pin-out on altera.com.
Go https://www.altera.com/products/fpga/cyclone-series/cyclone-iv/support.html Click 'Device Pin-Outs' Click 'Cyclone IV' Search 'EP4CGX15' and click Pin-Outs (XLS) Your device 'F14' package has 169 pins, so refer to column F 'F169'. I hate this translation :( Accoding to the spreadsheet, M7 pin is located in Bank B4, the function of the pin is CLK14 or DIFFCLK_6p. This is the best choice for clocks. I always uses differential I/O standard for clocks to avoid unexpected behavior caused by glitch on the clock, so I use DIFFCLK_*p pins. D10 is a general I/O pin, it should be good. R1 and R4 cannot be found in the spreadsheet. They must be changed to proper pin locations. I hope this helps you.
