10 years agoCyclone IV GX Transceiver Starter Board Clock Enable Ports
Hi, i am searching the clock enable input and output ports for the Cyclone IV GXEP4CGX15BF14 device. I have searched in different data sheets but i cannot find the clock enable ports. I on...
10 years agoHi, as I understand it, there is no specific clock enable pin in the CIV GX devices. If you would like to control the clock signal, you can use the ALTCLKCTRL instance when you can enable the clock enable control signal for the input clock.
