14 years agoCyclone IV GX PCIe SOPC design
Hello all, First I would like to inform you that I am new to this forum as I am to FPGA development. I am trying to create an FPGA based PCIe endpoint device using Altera's Cyclone IV FPG...
14 years agoGuys, thanks for your posts and I agree with you that Altera didn't do its best to provide a well structured or sufficient documentation for a rapid hands on experience.
Meanwhile the problem was solved ! The problem was the lack of a RESET signal routed into the PCIe block. Here is the solution, maybe there are others who can benefit from it. I will describe only the mandatory connections: INPUT connections: -> fixedclk ( 100 Mhz clock, NOTE: it must be derived from a source other than the free running PCIe clock ( here refclk ))-> reset_n ( reset source for the PCIe hard IP core (active low) it should be bound to high or to an external reset source ) -> pipe_mode ( connected to '0' (Virtual Pin) ) -> reconfig_clk ( connected to '0' (Virtual Pin) ) -> reconfig_togxb [3..0] ( connected to '2' (b0010) (Virtual Pins) ) -> refclk ( 100 Mhz (settings in PCIe compiler must match clock sources) ) -> rx_in0 ( RX line(s) - this design uses PCIe X1 ) -> others -> unconnected OUTPUT connections: -> tx_out0 ( TX line(s) - this design uses PCIe X1 )
-> others -> unconnected On the forum some remarked that it is needed an external reconfiguration block (ALTGX_RECONFIG) , it seems that this is unnecessary and using the constant values described above for the reconfiguration block pins should be enough. Hope this helps.
