11 years ago
Cyclone IV E Configugation pin MSEL3 issue
Hi, I need some help with Cyclone IV E configuration.
EP4CE22F17 does not have MSEL3 pin and handbook says:
--- Quote Start ---
Smaller Cyclone IV E devices or package options (E144 and F256 packages) do not
have the MSEL3 pin. The AS Fast POR configuration scheme at 3.0- or 2.5-V
configuration voltage standard and the AP configuration scheme are not supported in
Cyclone IV E devices without the MSEL3 pin. To configure these devices with other
supported configuration schemes, select MSEL2..0 pins according to the MSEL
settings in Table 8-5.
--- Quote End ---
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyclone-iv/cyiv-51008.pdf
Ok, that sounds good, but which MSEL3 pin value I must assume when looking in that table?
0, 1 or equal to some other MSEL pin?
    I would ignore the MSEL3 column as it does not apply. Also as it says in the test, ignore AS Fast POR 3.0/2.5 and all AP configurations. So if you want Standard 3.3V AS then you would set MSEL[2..0] to be 0,1,0
    --- Quote Start ---
    --- Quote End ---
    Doesn't matter. When you remove AS Fast for 3.0/2.5 and the AP options, you don't have any overlap if you ignore MSEL3.
    Looking at the table, it doesn't look like they internally tie MSEL3 it to a specific value or one of the other MSEL pins, so they must be using a different method in that case.
    Pete
