14 years agoCyclone IV configuration problem
Hi All, I have a problem with a Cyclone IV device not working correctly on my own hardware PCB. If I connect to the board using a USB blaster cable, Quartus can see the device correctly. I...
14 years agoI made a dev board with Cyclone 1 EP1C3T100 ( QFP 100 pins ). The board works perfectly until one of my students used it. After that the FPGA behaved like you said: it can be programmed ok with USB-Blaster+Quartus but the I/O don't work.
With careful and patience I remove the chip and put it a new one. It comes to life again. Can you remove the fpga?
