14 years agoCyclone IV configuration problem
Hi All, I have a problem with a Cyclone IV device not working correctly on my own hardware PCB. If I connect to the board using a USB blaster cable, Quartus can see the device correctly. I...
14 years agoin reply to bertulus> Thanks for the reply. DEV_OE is not enabled (neither is DEV_CLRn). I tried settings for both passive serial configuration (i.e. JTAG over a download cable) and also active serial. The MSEL pins are setup for AS config, although I believe these are ignored when using JTAG anyway? Unused pins are set as inputs tri-stated.
Thanks, Waljit.
