14 years agoCyclone IV configuration problem
Hi All, I have a problem with a Cyclone IV device not working correctly on my own hardware PCB. If I connect to the board using a USB blaster cable, Quartus can see the device correctly. I...
14 years agoAre you using a part with an exposed pad on the bottom? I've seen this type of behavior when the pad is not connected to ground. In particular the CONF_DONE at ~1V is a tip-off.
