14 years agoCyclone IV and Nios II Firmware Update
Hallo Everybody, I would like you guys to suggest a solution for the problem below: I have successfully updated the hardware and software configurations of my project on the EPCS device ...
14 years agoOk.. Here is the thing. I used the flash file i am programming, and used the Nios2-flash-programmer to program my flash. It works great. See below the log.
bash-3.1$ nios2-flash-programmer --epcs --base=0x3001800 "c:/User/kaushik/WIDri ve/flash/Firmware.flash" --program --erase-all --go Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Checksummed/read 896kB in 21.2s Erased 7680kB in 95.1s (80.7kB/s) Programmed 881KB +15KB in 6.8s (131.7KB/s) Did not attempt to verify device contents Starting processor at reset vector (0x03001800) If you see the last but one line it says, programmed 881KB + 15kB. What is this 15 kB.. Is it more metadata required for the correct booting of the system??
