14 years ago
Cyclone IV & 2xDDR2 connection
I am not very familiar with DDR components and I don’t want to miss anything or make errors in my design. I try to follow the cyclone III dev kit schematic (TPS51100 to generate Vref and Vtt for example) but it uses external terminations and I don't have much place on my board.
components :
=> Cyclone IV EP4CE30 (1 DDR <-> bank 3 & 4 // 1 DDR <-> bank 7 & 8)
=> 2xDDR2 MT47H32M16-25E
fpga side :
VCCIO : +1.8V (bank3,4,7,8)
- rup2 : 49.9Ohm pull-up to +1.8V / rdn2 : 49.9Ohm pull-down to GND
- rup4 : 49.9Ohm pull-up to +1.8V / rdn4 : 49.9Ohm pull-down to GND
- point to point connected to DDR2 devices
pinout parameters :
- IO standard = SSTL 18 class I
- output termination = series 50ohm with calibration (dq, dqs)
- assignment/timings verified by compilation
ddr2 controller parameters (hpc2) :
- memory drive strength setting = reduced
- memory ODT setting = 50 ohms
- memory format = discrete device
Do I miss something ?
Do I have to connect FPGA Vref IO (VREFBxNy) to DDR Vref (0.9V) ?
Do I have to add series resistor on ADDR / command signals and parallel resistor between differential ck/ck_n ?
Thanks for helping.
SG
1 Reply
    --- Quote Start ---
    components :
    fpga side :
    pinout parameters :
    Thanks for helping.
    SG
    --- Quote End ---
    e-mail me [email protected]
