Michael-C
2 years agoCyclone IV - LVTTL causing FPGA to reset
I am using a Cyclone IV FPGA with a Nios Core. I have 22x LVTTL PIO defined to remain tristate and drive low when active. The VCCIO of the bank on the FPGA is tied to +3.3V. This PIO is connected to...
AqidAyman_Altera
2 years agoWhen you mentioned the FPGA reboot, you meant the NIOS II getting reboot only and not the whole FPGA including the I/O right?
Have you check the scope shot from the waveform of the output switching whether it has a smooth transition or a lot of spikes coming in?
Also, which two PIO that you said it is working normally?
