18 years agoCyclone III using 3.3V power supply
Hi there,
my embedded system is based on a Cyclone III powered using an external 3.3V power supply. I already found the solution used in DK-DEV-3C120N to drive 1.2V (core) and 2.5V (PLLs) using a 3.3V supply. But I'm still locking for a smart solution (i.e., low price and small area) to supply a smaller device (i.e., EP3C40F484C6N) with a lower power consumption efficiently. Can anyone help me with that? Thanks in advance Modellpilot4 Replies
i use en5312(enpirion) for core voltage(ep3c25/ep3c16).
To give a ballpark figure, we are talking about 300..500 mA. Do you have any suggestions regarding the voltage regulator (maybe including a schematic)?
The best soultion depends mainly on the power demand of your application, particularily for core supply. It may range from a few 10 mA to several A. Linear voltage regulator solution may be suitable up to at least some 100 mA, it's clearly the cheapest solution.
