18 years agoCyclone III using 3.3V power supply
Hi there, my embedded system is based on a Cyclone III powered using an external 3.3V power supply. I already found the solution used in DK-DEV-3C120N to drive 1.2V (core) and 2.5V (PLLs) using...
18 years agoThe best soultion depends mainly on the power demand of your application, particularily for core supply. It may range from a few 10 mA to several A. Linear voltage regulator solution may be suitable up to at least some 100 mA, it's clearly the cheapest solution.
