16 years agoCyclone III PLL cascading - lack of information
Hi everyone! I try to run a Design with two PLLs. The first one not reconfigurable, inclk from dedicated clock pin (100MHz), located in PLL1. The second one is reconfigurable, inclk from the first...
16 years agoFinally... it works!
The only thing I had to do is to change the location of the reconfiguarable PLL from PLL 3 to PLL 2. This is reproducible. I did not use PLL specific stuff like differential clock output ports or such things. There is only one PLL output connected with a GPIO. So I wonder why the location of the PLL has an influence on the synthesis result.
