16 years agoCyclone III not configuring
I have a 144 pin cyclone 3 that I'm trying to get working in a board design I've done. It is not configuring. I can see the TCK on the oscilloscope but no TDO data comes back from the FPGA.
The nConfig and nStatus pins are both high and the CONF_DONE flag is low. I went through the altera trouble shooter but with no luck. One issue is that a ground pin and VCCA pin were shorted together when I first put the chip on the board. It got really hot when I turned it on and the voltage levels were screwed up. I'm not sure if I fried the chip. CONF_DONE is pulled high with a 10k resistor so the fact that it is low made me think the chip was still good. I've ordered some more chips and I'll try them out if I figure something else out first. Thanks.
