18 years agoCyclone III Nios problem
I'm using Cyclone III EP3C25F324C8. I'm trying to run the hello world progarm in Nios but it is giving me following error
Verifying 02000000 ( 0%) Verify failed between address 0x2000000 and 0x200FE63 Leaving target processor paused My SOPC builder has DDR SDRAM. I had a critical warning in timing analyser saying Critical Warning: Timing requirements for slow timing model timing analysis were not met. See Report window for details. Is it because of this warning. Is so how can i solve this problem?1 Reply
You are getting memory errors due to the timing problems.
How far did you optimize your design to meet the timing requirememts? Maybe you still can activate some more optimization options and achieve a better timing. (e.g. Perform pyhsical synthesis for combinational logic, register duplication, register retiming, etc). If that still doesnt help, maybe place the DDR in a design partition and compile it alone before you add the other modules. How bad is your timing? How full is the FPGA? Lokla
