8 years agoCyclone III EP3C10F256C6N bank1 1.8V setting
https://alteraforum.com/forum/attachment.php?attachmentid=14936&stc=1 Hi, Use EP3C10F256C6N the Bank 1 can't setting to standard 1.8V detail as attach img. Which setting should I need? ...
8 years agoUnreadable .jpg attachment. Try with different image formats to bypass the forum software image downsizing, and review your posts after sending it.
The requirement is that all IO-standards assigned explicitly (or implicitly by defaults) in a bank must be compatible. Bank1 contains the configuration pins, Quartus doesn't recognize 1.8V as legal configuration pin voltage. Only in case of PS scheme, you are able to override the check, but it's not possible for AS or FPP.
