18 years agoCyclone III Dedicated clock inputs during configuration
Hi All:
We have a question about the state of Dedicated Clock Inputs during configuration on Cyclone III devices. The handbook says that the "Programable Pull-up Resistors" are not available on the dedicated clock input pins. Is this also true during configuration? IE they will not have a weak pullup during configuration? If the dedicated clock inputs are not used, and you have unused pins set as input w/weak pullup With the unused clock inputs not have the pullup in this case as well? Thanks Pete3 Replies
I wouldn't expect dramatic consequences, only a slightly increased current consumption is likely to happen.
--- Quote Start --- If you're not using the dedicated clock input, you're supposed to tie it off(directly high or low, or a pull-up/down). --- Quote End --- Hello Rysc, What is the implication if one doesn't tie off the unused dedicated clocks? - Altera_Forum
I'm pretty sure it means they don't physically exist, and therefore there is no way for them to have a pullup during configuration. If you're not using the dedicated clock input, you're supposed to tie it off(directly high or low, or a pull-up/down).
