18 years agoCyclone III Dedicated clock inputs during configuration
Hi All: We have a question about the state of Dedicated Clock Inputs during configuration on Cyclone III devices. The handbook says that the "Programable Pull-up Resistors" are not avai...
18 years ago --- Quote Start --- If you're not using the dedicated clock input, you're supposed to tie it off(directly high or low, or a pull-up/down). --- Quote End --- Hello Rysc, What is the implication if one doesn't tie off the unused dedicated clocks?
