18 years agoCyclone III configuration
I'm about to spin my Cyclone 3 board and want to be sure I get the configuration stuff wired correctly. I'm using a JTAG connection to the USB Blaster and a Serial Config Device (active serial)...
18 years agoI'm about Cyclone III ep3c5e144.
JTAG lines behave strangely. I connected the JTAG pull-ups to VCCA which is 2.5 Volts. But they are equal to 0. MSEL = 101 (to VCCA). When I connect to ByteBlaster-MV (VCCA 2.5 V) I see signals at the inputs (TDI, TMC, TCK), but TDO is always 0!! So programmer can't see board ("Can't acces JTAG chain"). Everything was good with Cyclone, CII. What I do not understand? What did I miss? Thanks.
