18 years agoCyclone III configuration
I'm about to spin my Cyclone 3 board and want to be sure I get the configuration stuff wired correctly. I'm using a JTAG connection to the USB Blaster and a Serial Config Device (active serial)...
18 years agothis question is there is a cs pin of ADI level shifter ,it used the voltage of USB cable.so you must use the usb cable connect to PC.
