18 years agoCyclone III configuration
I'm about to spin my Cyclone 3 board and want to be sure I get the configuration stuff wired correctly. I'm using a JTAG connection to the USB Blaster and a Serial Config Device (active serial)...
18 years agoNot using bank 1 & 6 at all is actually great news for your purposes!
Remember, just because you do not use a particular bank does not excuse you from powering each bank with some voltage! In your case, just go ahead and connect the Vccio for those banks to 2.5 volts (as well as any other bank you are not planning to use. Hope this helps.
