13 years agoCyclone III Configuration
I am bring up a board with a Cyclone III (256 pin). I have connectors for JTAG and the byte-blaster. MSEL0 = 0, MSEL1 = Vcca(2.5V), MSEL2 = 0. I can load the configuration via JTAG and I can ...
13 years ago --- Quote Start --- The other supplies are turned on by a micocontroller. --- Quote End --- If the supplies are used by the Cyclone, then make sure the power-on sequence meets the requirement of the FPGA power-on-reset. If it does not, then you may have to assert nCONFIG low until all the supplies are valid. --- Quote Start --- Good idea to check for clock, you nailed it! I find no clock on my oscillator IC, investigating.... --- Quote End --- Check for a 180-degree rotation of the part ... darned rotationally symmetric parts ... :) Cheers, Dave
