14 years agoCyclone III configuration scheme
Hi I'm confuse with Cyclone fpga family and configuration schemes. In school we have an Altera board with a Cyclone II fpga, I know that the board use an EPC2 configuration device and w...
14 years ago --- Quote Start --- Then, the second scheme (JTAG) is like figure 9-30 ? http://www.altera.com/literature/hb/cyc3/cyc3_ciii51016.pdf --- Quote End --- Yes, this scheme supports configuration from EPCS, and reprogramming of the EPCS device via JTAG. However, you must take care and read the footnotes - (2) indicates that you need to refer to Table 9–7 on page 9–11 for the MSEL options that can be used with AS mode. --- Quote Start --- How should I connect MSEL pins? according to table 9-7 all pins to GND is ok? --- Quote End --- Grounding all MSEL pins is not a valid Active Serial (AS) mode. Re-read the table, and you'll see several options for AS mode. The mode to select depends on the rest of your board design. Cheers, Dave
