15 years agoCyclone III configuration query
Hi, I have a query for CycloneIII device configuration. Can SPI based flash memories like 25LC512 be used with Cyclone III device for Active serial configuration mode? If not, then what ...
10 years agoHi MMartin71,
Where did you get the POF file? The scenario you described means that the configuration is unsuccessful. I do not think that M25p64 part number is available in Quartus. But since it is recognized as EPCS64, you can try to generate your own POF file through Quartus and configure into the M25p64 via Quartus Programmer and see if it works?
