17 years agoCyclone III configuration problem
Hi I am using EPCS16 to configure Cyclone III EP3C25E device in AS mode. I load the pof configuration file into EPCS16 using external Speedpro 3000A third party programmer (JTAG is not used at all). ...
17 years agoThe external conditions for releasing POR are described in the hardware manual. If nSTATUS is low, although it has a correct pullup, I would expect POR condition.
--- Quote Start --- The POR circuit keeps the device in reset state until the power supply voltage levels have stabilized on power-up. Upon power-up, the device does not release nSTATUS until VCCINT, VCCA, and VCCIO of banks 1, 6, 7, and 8 are above the device’s POR trip point. On power-up, VCCINT and VCCA are monitored for brown-out conditions. --- Quote End --- A JTAG interface would be generally helpful in further clarifying the issue.
