13 years agoCyclone III configuration problem with Active Parallel flash
Hi, All, I've trying to store mt configuration and code data in an external flash, via Active Parallel interface. Using the Flash Programmer, I'm able to burn the .flash file to the external fla...
13 years agoOk, I got it after talking to Altera support.
It seems I needed to follow the instructions written in "NIOSII Evaluation user guide, Cyclone III edition": http://www.altera.com/literature/ug/niosii_eval_user_guide.pdf Once I did the steps stated in page 69 and forward, I managed to place the configuration and application data both in the flash memory, and boot from the flash. Still, this is a mystery. There's hardly any explanations as to why those steps work. Altera should take note- the documentation on this feature is not good enough. Does anyone know of an app note or such that explains the boot process of the cyclone 3, the flash contents, etc? Ran
