13 years agoCyclone III configuration problem with Active Parallel flash
Hi, All, I've trying to store mt configuration and code data in an external flash, via Active Parallel interface. Using the Flash Programmer, I'm able to burn the .flash file to the external fla...
13 years agoThanks for the reply, Daixiwen.
I tried changing the reset address- still no good. I noticed in some application note a mention about 'Configuration Controller' for the FPGA. I wasn't able to understand exactly if it's a must or just an option. Any one knows? Ran
