14 years agocyclone III configuration chain problem
Hi, I have two EP3C25Q240 cyclone III fpgas on my board with the EPCS16 configuration device. The system is set up for multi device AS configuration as per figure 9-4 in the cyclone device ha...
14 years agoHi Gary,
--- Quote Start --- I now know what the issue was. I believe that U18 was causing too much delay so the enable was not enabled until 1 clock too late and hence it always failed to config. Changing U18 to a direct through path with pull up to 2V6 solved the problem. --- Quote End --- Glad to hear you got things working! Thanks for taking the time to update the forum with your solution. Cheers, Dave
