12 years agoCyclone III: can't achieve specified port rate
I have problems to meet timing requirements, getting "minimum pulse width"-violations with "port rate"-type. Design consists of clock input (50MHz, pin_t9), PLL and clock output(100MHz, pin_l1). Device is EP3C25U256C8. Current strength @8mA, slew rate 2. Timequest reports "minimum pulse width"-violations at the clock output with -3.481 slack. If I understand it correctly, the output toggle rate is specified up to 200MHz with this settings. Any suggestions what the problem is? Best regards JaroslavNo RepliesBe the first to reply
