19 years agoCyclone III AS configuration bizarreness
I am using a cyclone III (EP3C25F324C8N) with an EPCS16 configuration device. I am programming the configuration device through the FPGA with the serial flash loader. The problem is that the Cyc...
14 years agoYou possibly need an active probe to see the CLK signal undistorbed, The final cause for configuration problems related to JTAG signal quaility is often a non-monotic, ringing CLK edge, which is seen as double clock edge by the JTAG logic. A small capacitive load like the 10 or 12 pF of a standard passive 10:1 oscilloscope probe can be already sufficient to fix the problem.
Placing a small capacitor, e.g. 15 or 22 pF between TCK and ground near the FPGA would be my first try to solve issue.
