19 years agoCyclone III AS configuration bizarreness
I am using a cyclone III (EP3C25F324C8N) with an EPCS16 configuration device. I am programming the configuration device through the FPGA with the serial flash loader. The problem is that the Cyc...
18 years agoThank you for the post. I am running at very low frequency (8.192MHz), therfore, waveforms look very clean. I confirmed that using an osciloscope.
I had the probes atttached to CLK and DATA while I was programming the FPGA so if the probes are reason for clean waveforms, they were attached during the whole event. I do not think that data is wrong because with 75 us pause between the bursts the /STATUS never goes low, which should mean that all checksums are OK. I am so confused...
