19 years agoCyclone III AS configuration bizarreness
I am using a cyclone III (EP3C25F324C8N) with an EPCS16 configuration device. I am programming the configuration device through the FPGA with the serial flash loader. The problem is that the Cyc...
18 years agoHi Frank,
Are you suggesting that ringing on DCLK could be being interpreted as extra clock edges? There is 30mm between FPGA and EPCS - no other devices are connected to DCLK. There is a ground layer and a 3V3 layer on the PCB. Adding a series resistor isn't as easy to implement in practice but I will give it a try. I suppose that if the scope is affecting the amount of ringing then it will be difficult to see the difference between a series R and the 100pF to GND accurately. Thanks for your help.
