16 years agoCyclone III and 400 Msps DAC
I want to drive a 400 Msps DAC (DAC5675A) with EP3C16Q240C8. The FPGA 's PLL cannot create a 400 MHz clock for the DAC due to hardware constraints, although it can produce 400Mps LVDS DATA thanks to ...
16 years agoYes, this should work. You can output a testpattern, determine the clock phase limits, that still achieve correct DAC output and set the phase shift to the mean value.
