16 years agoCyclone III and 400 Msps DAC
I want to drive a 400 Msps DAC (DAC5675A) with EP3C16Q240C8. The FPGA 's PLL cannot create a 400 MHz clock for the DAC due to hardware constraints, although it can produce 400Mps LVDS DATA thanks to ...
16 years agoYes, the C8 output toggle rate is limited to 320 MHz. So you need an external clock doubler circuit. Using a faster (C6 + BGA package) CIII version may be the more simple solution. The 200 MHz LVDS clock can be still generated from an internal PLL in my opinion. A fine tuning of LVDS versus external 200 MHz clock phase is most likely necessary, but basically a simple action.
