17 years agoCyclone III + EPCS + Remote Update
As the title suggests, we want to implement the remote update feature using the CIII and (Active Serial) EPCS64 device. The objective is to get two application programs stored on the EPCS device, b...
14 years agoHi fifamanutd, this code is an example code to configure and trigger the reconfiguration. You can use the remote_update core on both images (same for the code) if you want to switch between imagens whenever you feel like, but you need to have it at least at factory image...
Try reading the Remote Update Megafunction User Guide and the SOPC Remote Update user guide (Embedded Peripherals IP User Guide). Cheers
