17 years agoCyclone III + EPCS + Remote Update
As the title suggests, we want to implement the remote update feature using the CIII and (Active Serial) EPCS64 device. The objective is to get two application programs stored on the EPCS device, b...
16 years agoHi Kevin,
What are you using to read/write to the EPCS (SPI flash)? I've only ever used the epcs_controller in an SOPC Builder system with Nios II. Doing it this way, I read/write to the EPCS using the epcs_controller and use the altremote_update block to trigger appropriate resets... Regards, --slacker
