17 years agoCyclone III + EPCS + Remote Update
As the title suggests, we want to implement the remote update feature using the CIII and (Active Serial) EPCS64 device. The objective is to get two application programs stored on the EPCS device, b...
16 years agoSlacker - thanks for your response, I did try this with an 11Mhz clock but see the same behavior.
I am running with the image loaded from sector 0x0 so I believe I am in Factory Config mode and since the data I write does come back on a read... albiet from the wrong address, it seems to be accepting the write. I just don't understand why I can't read from the offset that I am writing. Thanks Kevin.
