14 years agoCYCLONE III - EPCS16 - AS MODE and FLASH PROGRAMMING
Hi all, this is santhosh. i am not too much into fpga's.... we are utilizing an altera cyclone iii board for a energy meter purpose. We have made a board for the application.i find that in my...
14 years agoOk i have observed some thing... but still put me into dead end.
In the Qsys, the EPCS controller has not been exported. The component is not accepting the option to use dedicated AS pins. It says its not supported. So i exported the pins and then assigned the corresponding pin numbers. I have also cross checked that the pins are marked as "Regular I/Os" in the dual purpose pins tab in device settings. still i am getting error in fitting.... Error (176310): Can't place multiple pins assigned to pin location Pin_12 (IOPAD_X0_Y27_N7) Info (176311): Pin epcs_adso is assigned to pin location Pin_12 (IOPAD_X0_Y27_N7) Info (176311): Pin ~ALTERA_ASDO_DATA1~ is assigned to pin location Pin_12 (IOPAD_X0_Y27_N7) Error (176310): Can't place multiple pins assigned to pin location Pin_14 (IOPAD_X0_Y25_N0) Info (176311): Pin epcs_nce is assigned to pin location Pin_14 (IOPAD_X0_Y25_N0) Info (176311): Pin ~ALTERA_FLASH_nCE_nCSO~ is assigned to pin location Pin_14 (IOPAD_X0_Y25_N0) Error (176310): Can't place multiple pins assigned to pin location Pin_23 (IOPAD_X0_Y22_N0) Info (176311): Pin epcs_dclk is assigned to pin location Pin_23 (IOPAD_X0_Y22_N0) Info (176311): Pin ~ALTERA_DCLK~ is assigned to pin location Pin_23 (IOPAD_X0_Y22_N0) Error (176310): Can't place multiple pins assigned to pin location Pin_24 (IOPAD_X0_Y22_N7) Info (176311): Pin epcs_data0 is assigned to pin location Pin_24 (IOPAD_X0_Y22_N7) Info (176311): Pin ~ALTERA_DATA0~ is assigned to pin location Pin_24 (IOPAD_X0_Y22_N7) Info (171121): Fitter preparation operations ending: elapsed time is 00:00:01 Error (171000): Can't fit design in device Error: Quartus II 32-bit Fitter was unsuccessful. 5 errors, 3 warnings Error: Peak virtual memory: 345 megabytes Error: Processing ended: Tue Sep 11 14:56:58 2012 Error: Elapsed time: 00:00:33 Error: Total CPU time (on all processors): 00:00:18 Error (293001): Quartus II Full Compilation was unsuccessful. 7 errors, 987 warnings
