14 years agoCYCLONE III - EPCS16 - AS MODE and FLASH PROGRAMMING
Hi all, this is santhosh. i am not too much into fpga's.... we are utilizing an altera cyclone iii board for a energy meter purpose. We have made a board for the application.i find that in my...
14 years ago:(:(:(
Hi..... I have tried the older version, which was working earlier also. Same error. I am attaching the full stack trace of the eror... Info: Sep 11, 2012 9:14:18 AM - (FINE) sof2flash: Starting Info: Info: ******************************************************************* Info: Info: Running Quartus II Convert_programming_file Info: Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=G:/qcon/qcon_fpga_card/quartus/qcon_v0/software/io_processor_nios11_bsp/flash/qcon_v0_epcs_flash_controller_0.opt G:/qcon/qcon_fpga_card/quartus/qcon_v0/qcon_v0.sof G:/qcon/qcon_fpga_card/quartus/qcon_v0/software/io_processor_nios11_bsp/flash/qcon_v0_epcs_flash_controller_0.pof Info: Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Info: Peak virtual memory: 131 megabytes Info: Info: Processing ended: Tue Sep 11 09:14:26 2012 Info: Info: Elapsed time: 00:00:03 Info: Info: Total CPU time (on all processors): 00:00:02 Info: Info: ******************************************************************* Info: Info: Running Quartus II Convert_programming_file Info: Info: Command: quartus_cpf --no_banner --convert G:/qcon/qcon_fpga_card/quartus/qcon_v0/software/io_processor_nios11_bsp/flash/qcon_v0_epcs_flash_controller_0.pof G:/qcon/qcon_fpga_card/quartus/qcon_v0/software/io_processor_nios11_bsp/flash/qcon_v0_epcs_flash_controller_0.rpd Info: Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Info: Peak virtual memory: 128 megabytes Info: Info: Processing ended: Tue Sep 11 09:14:29 2012 Info: Info: Elapsed time: 00:00:03 Info: Info: Total CPU time (on all processors): 00:00:02 Info: Sep 11, 2012 9:14:29 AM - (FINE) sof2flash: Done Info: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Info: Resetting and pausing target processor: OK Info: Reading System ID at address 0x00084188: verified Info: Processor data bus width is 32 bits Info: Looking for EPCS registers at address 0x00083800 (with 32bit alignment) Info: Initial values: 0001703A 04C00074 9801483A 9CFFF804 983FFD1E 0000203A Info: Not here: reserved fields are non-zero Info: Looking for EPCS registers at address 0x00083900 (with 32bit alignment) Info: Initial values: 92400237 4A40100C 483FFD26 90000135 92400237 4A40200C Info: Not here: reserved fields are non-zero Info: Looking for EPCS registers at address 0x00083A00 (with 32bit alignment) Info: Initial values: 108001C4 1004D0FA 002EE03A 003F9C06 002EE03A 003F9506 Info: Not here: reserved fields are non-zero Info: Looking for EPCS registers at address 0x00083B00 (with 32bit alignment) Info: Initial values: 00000000 00000000 00000000 00000000 00000000 00000000 Info: Not here: SPI_SLAVE_SEL has 0 valid bits (should be between 1 and 16) Info: Looking for EPCS registers at address 0x00083C00 (with 32bit alignment) Info: Initial values: 00000000 00000000 00000260 00000000 00000000 00000001 Info: Valid registers found Info: EPCS signature is 0x00 Info: EPCS identifier is 0x000000 Info: No EPCS layout data - looking for section [EPCS-000000] Info: Unable to use EPCS device Info: Leaving target processor paused Error: Error code: 8 for command: $SOPC_KIT_NIOS2/bin/nios2-flash-programmer "G:/qcon/qcon_fpga_card/quartus/qcon_v0/software/io_processor_nios11_bsp/flash/qcon_v0_epcs_flash_controller_0.flash" --base=0x83800 --epcs --sidp=0x84188 --id=0x0 --timestamp=1347252982 --device=1 --instance=0 '--cable=USB-Blaster on localhost [USB-0]' --program --verbose Also attached the BSP_EDITOR for my project. Kindly try to help, meanwhile i ll try other resources in Altera forum also. san
