14 years agoCyclone III -- IO port in VHDL help
I'm writing a small code to simulate the I2C. In VHDL, the "sda_io" is defined as an IO port. I thought this simple statement should work: sda_io <= '0' when drive_sda = '1' else (other => '...
14 years agoCheck the synthesis results. Once upon a time, the recommended syntax for a tri-state was to have the 'Z' first, i.e.,
io <= 'Z' when (io_oe = '0') else io_out;
But that could have been 'fixed' in newer versions of the tools. Cheers, Dave
