Cyclone II Quartus Legacy Support
- 4 years ago
Please ignore post. One Intel download page only cites repositories that go back to 13.2, but this link brings you to a page that includes versions back to 2.2 -- Yikes!
- Jaguar14 years ago
I'm the same boat as the original poster. I've registered and logged in, but still only see Quartus version13.1 and newer. is anyone else able to see and download the older versions?
- ak6dn4 years ago
I still see 13.0sp1 available for download:
Thanks ak6dn. I installed it and the first thing I noticed is lack of support for the SOPC build, which gets to the heart of my problem, which is core IP upgrades. I've already tried some earlier versions, to no avail. My issue is that the cores were generated by Quartus 7 (or 6, depending on whether I believe the output files or the SOPC builder opening dialog). I think this means I have to upgrade the cores starting with with either the last version of Quartus supporting the System Wizard or the earliest version supporting the SOPC builder (versions 6 and 7 which I was hoping to download and try). The main upgrade issue appears to be the DDR2 core. See below for an excerpt the generation report, ddr2_sdram.html).
All the generated files are present but I can't seem to get it to install using the SOPC builder. Qsys is even worse and omits all the cores during the upgrade. As a last resort, I suppose I can regenerate the library module with the "new component" option and add it back to the design, but I was hoping for an option that gets us closer to the original HDL as the verification and validation starting point.
Potentially complicating matters, judging from experimenting with different Quartus versions, there seems to be a point where the Quartus DDR2 core (I don't remember exactly but sometime between versions 10 and 12) where Quartus no longer supports Cyclone II, but before that Quartus version, this particular DDR2 core is not available. That's why I wanted to try version 7. Appreciate any further comments or suggestions.
Generation Report - DDR2 SDRAM Controller v7.0
Entity Name ddr2_sdram_auk_ddr_sdram Variation Name ddr2_sdram Variation HDL Verilog HDL Output Directory (omitted) File Summary
The MegaWizard interface is creating the following files in the output directory:File Description ddr2_sdram.v A MegaCore® function variation file, which defines a Verilog HDL top-level description of the custom MegaCore function. Instantiate the entity defined by this file inside of your design. Include this file when compiling your design in the Quartus II software. ddr2_sdram_bb.v Verilog HDL black-box file for the MegaCore function variation. Use this file when using a third-party EDA tool to synthesize your design. [etc etc.]
- ak6dn4 years ago
QuartusII Web (Lite) 13.0sp1 for CycloneII is back up on the download page as of this posting time (2022-01-09 10:00am PST).
https://fpgasoftware.intel.com/13.0sp1/?edition=web&platform=windows
Get it while it is still available...
BTW other earlier versions show as downloadable, but if you select them they go to a page that says not available.
