18 years agoCyclone II PLL Skew?
Hello, How can i determine the max clock skew on an output pin on my Cyclone II? I would like to know if clock skew could be significant enough to warrant being part of the SDC constraints for ...
18 years agoYou can account for the jitter with set_clock_uncertainty if the Cyclone II handbook has a separate spec for output jitter when using an I/O pin. If it's not in the handbook, you'd have to guess how much clock uncertainty to add. I was probably looking at Cyclone III when I saw a separate spec in a handbook. If the Cyclone II handbook doesn't have the separate jitter specs, you could use the difference in jitters in the Cyclone III handbook for a rough guess for the Cyclone II difference. In Cyclone II, the guard bands in the timing model might be enough to cover the jitter for a dedicated clock output with no set_clock_uncertainty, but don't assume the guard bands cover the additional jitter for an I/O output.
As Jake said, Quartus accounts for the skew automatically, but you do have control over how much the skew is. Driving a clock output from a PLL to an I/O pin directly probably has more skew relative to the data outputs than you would have if you drove both clock and data outputs with I/O cell registers configured the same way. The PLL output would clock the I/O cell DDIO registers that have their data inputs hard wired to high and low. You use the same PLL output for data and clock registers if you don't need a phase shift and a separate PLL output for the clock registers if you do need a phase shift.
